Another power steering conversion question
Old Apr 8, 2005 | 01:38 PM
1965-f100's Avatar
1965-f100
Ok - need some help. Looked at the past posts and thought I had what I needed. Here is the situation. I have a 73 f100- 2WD- 6-cylinder manual column shift. I just bought a 77 F100 - 2wd - 6 cylinder automatic with power steering. From what I read - I thought I should be able to just swap out the center shaft along with the p.s. box, pitman arm, etc. The shaft out of the auto column is shorter, but seems to be about 1/8"-1/4" too short. I can't get the steering wheel nut back on. I've checked to make sure that it is seating properly at the bottom of the column and took the little c-clip off of the automatic column that the manual column did not have. Still - no luck. Is there anything I'm missing here?
Thanks
Brad
