1981 F150 Electrical System Problems
Old Apr 8, 2005 | 11:52 AM
vicblak's Avatar
vicblak
hello out there- got a quick question i'm hoping someone can help with. i've got an 1981 6cyl F150 2wd PickUp.
earlier this week, my dash light went out, as did my tail lights. took it to my mechanic- told me some wires were fried- fixed them up. drove about 5 minutes- got a nasty slight odor toxic taste in my, and couldn't breathe really. stopped the car- looked under the hood- found nothing- no smoke - nothing. got back in the car- dead. starts w/ a jump, but doesn't last long- headlamps flicker, fade, stall.
another jump gets me back to mechanic- replaces my alternator and voltage regulator. feel things are done- nope. no tail light or dash light. and now stereo sounds like a clock radio. engine start is long to kick over.
take it back- they tell me all wires behind dash are fried- going to be expensive. did these guys follow correct procedure, or thru negligence, made all the wrong moves, and made things worse?
any help on this one?
Old Apr 8, 2005 | 12:19 PM
ronclark's Avatar
ronclark
It looks like your mechanic fixed the symptoms and not the problem. He fixed the fried wires without repairing the short that caused the wires to fry the first time. Thus the repaired wires fried again and maybe this time produced enough heat to melt the insulation of other bundled wires causing more problems. Wires don't burn up for no reason. Fuses don't blow for no reason. Whenever you have a problem with burning wires or blowing fuses, you need to find and fix the short before repairs are complete.
Old Apr 9, 2005 | 09:20 AM
dmuncy's Avatar
dmuncy
Just a thought, check all of your grounding points. My brother-in-law had the same problem. afterscratching a hole in my hat,I finaly found a bad ground at the starter.
Old Apr 10, 2005 | 11:39 AM
5_labsownus's Avatar
5_labsownus
A guess is that the head light switch and wired to the plug are bad. This is a common problem and by your comment that the problem started with the dash lights and tail lights leads me to this as the start of the problem. It would be nice to know what wires he "fixed".
If the wires under the dash are now all fried you will need to get a harness from a doner.
BTclassics
Electrical Systems/Wiring
56
May 9, 2017 09:51 PM
6.9idiatsturbo
18
Aug 15, 2016 05:54 PM
zack753
Nov 21, 2015 08:46 AM
sgauvry
Sep 22, 2015 06:47 AM
hooptytank
Jul 27, 2015 10:26 AM
