General Automotive Discussion
Saving Gas???
Old Apr 8, 2005 | 10:51 AM
F250kid's Avatar
F250kid
Question Saving Gas???
Hey can anyone tell me if dropping into first gear on an automatic to slow yourself down at a light saves gas or uses up more gas?? sorry I'm an idiot!! LOL. thanks for any information setting me strait!
Old Apr 8, 2005 | 11:14 AM
bilter's Avatar
bilter
It would be about the same.
Old Apr 8, 2005 | 12:32 PM
85e150's Avatar
85e150
Uses more gas and uses more transmission. You don't need to do this. Anticipate the stop lights and time your self to avoid the red or coast up to the sign with minimal braking.
The less you use the brakes, including the engine as a brake, the less gas you will use.
And yes, this means driving like an old grandpa.
Old Apr 8, 2005 | 07:52 PM
76supercab2's Avatar
76supercab2
Fuel consumption has much more to do with throttle position than engine rpm. Many people confuse this because they know that fuel consumption goes up as speed goes up, also rpm goes up with speed. However throttle position increases with increased speed and rpm. In drive, my car is at 2000 rpm at 60mph. In neutral I can hit 2000 rpm with much less throttle. The difference, the amount of power the engine is being asked to produce.
Having said that, comparing closed throttle coasting to a stop to closed throttle engine braking, there is no difference in fuel consumption. The throttle position is the same in both cases.
Put another way, when the throttle is closed, little to no air flows so (in the case of carbs) little to no fuel is drawn from the carb. In the case of fuel injection, the throttle position sensor and oxygen sensor will be used by the computer to shut down fuel flow.
Old Apr 9, 2005 | 07:27 AM
jroehl's Avatar
jroehl
I just want to know why we call it a "gas pedal", when it's really an "AIR pedal".
Jason
Old Apr 9, 2005 | 12:34 PM
76supercab2
Because we pay for the gas. The air is free.
Old Apr 10, 2005 | 04:41 PM
sierraben's Avatar
sierraben
Don't know if this helps but one of the biggest power robbing device is your altenator. It can put somewhat of a big drag on your engine depending what accessories are on at the time. More throttle, more fuel. Just my opinion.
