Trans Problem
Old Dec 30, 2000 | 12:56 AM
Cfdchf's Avatar
Cfdchf
Trans Problem
My 92 F-150 E4od while coming to a stop the Trans shifted into low gear and won't shift up, it started whinning and refused to go into second gear. About a half mile of this or so and it popped and shifted REAL HARD !!!!! Now it still won't go into second but skips right into third gear. OD workes fine. Any Help ???????
Old Dec 30, 2000 | 01:17 AM
cgl's Avatar
cgl
Trans Problem
Have you checked the level of your tranny fluid? I've seen low levels cause hard shifts. Also check the color, it should be red or red-brown. If it's black, you have a problem.
Old Dec 30, 2000 | 08:46 PM
dwight1973's Avatar
dwight1973
Trans Problem
Same thing happened on my 92 F150. Turns out I needed to get my transmission rebuilt. Don't give it too much gas while in third or it will scare the heck out of you when it downshifts into first instead of second. My 302 did this with only 70,000 miles on it.
Old Dec 30, 2000 | 09:01 PM
nitro94's Avatar
nitro94
Trans Problem
