Cruise control conversion
Old Apr 7, 2005 | 06:03 PM
JerichoM1070's Avatar
JerichoM1070
Suprisingly my truck has, or rather had, cruise control. It has it on the turn signal indicator. I never really liked it there and it broke to get back at me. I came across a horn pad that has cruise on it. Has anyone ever converted to cruise on the wheel? Any help would be great.
88 f350 5spd
Old Jul 12, 2005 | 07:13 PM
JerichoM1070
Alright, I'm throwing this out again. I can't find parts for my turn signal-mounted cruise control so I was wondering how difficult it would be to run the wires to the horn-mounted cruise and it work.
Any help would be appreciated.
Old Jan 23, 2006 | 10:54 PM
JerichoM1070
Can't seem to get any help on this one...
Anyone know anything about cruise control on the wheel?
Old Jan 23, 2006 | 11:26 PM
slow_v6_stang's Avatar
slow_v6_stang
i know my '88 f-150 has it on the wheel...but it doesnt work
Old Jan 24, 2006 | 10:17 AM
JerichoM1070
Thanks slow v6,
Do you know if a tilt column with cruise on the wheel would bolt up and plug-n-play into my truck with cruise on the turn signal. And this is factory cruise on the signal.
Old Jan 24, 2006 | 10:19 AM
pfogle's Avatar
pfogle
If the cruise is on the turn signal arm then it was an aftermarket kit. I doubt that you will be able to use the ford factory parts.
Old Jan 24, 2006 | 10:27 AM
JerichoM1070
This one doesn't look like some of the aftermarket ones that I've seen - it looks a lot more like it is supposed to be there. I'll have to see if has a date code on it. If it turns out to be aftermarket, does anyone know a good brand to replace it with?
Thanks.
Old Jan 24, 2006 | 11:07 AM
andym's Avatar
andym
It is definitely aftermarket. Ford cruise control is on the horn pad on every truck.
