Stalls
Old Dec 29, 2000 | 09:48 PM
drh2810's Avatar
drh2810
Stalls
[font size="1" color="#FF0000"]LAST EDITED ON 29-Dec-00 AT 10:53 PM (EST)[/font][p]The radio, wipers, etc. stay on. Only noticed the tach going to zero and check engine light.
Switch replaced 18 months ago.
Thanks.
Old Dec 31, 2000 | 12:58 AM
hotrodford_88's Avatar
hotrodford_88
Stalls
Old Jan 1, 2001 | 08:20 AM
DannyP's Avatar
DannyP
Stalls
drh....I had a similar problem years ago with my 89. Check the wires on the fuel pump and EEC relays for corrosion. Mine were corroded in two and doing the intermittant thing you are describing. Pigtails can be bought at Ford for about $12.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Jan 1, 2001 | 10:00 AM
drh2810's Avatar
drh2810
Stalls
[font size="1" color="#FF0000"]LAST EDITED ON 01-Jan-01 AT 11:04 AM (EST)[/font][p]Thanks.
Are both on the driver side fender wells?
Thanks again.
Old Jan 1, 2001 | 11:26 AM
mjb007's Avatar
mjb007
Stalls
I had a similar problem. Mine wouldn't die out all the way. I would be going down the road and it would stall, tach and gauges would drop to zero for 1/2 second, then it would come back, doing this three or four times in a row (1/2 second on, 1/2 second off). We replaced the TFI module on the distributor but it didn't help. So I got up under the dash and pulled the computer out. Ran without the stalling. We put the computer back in and determined it wasn't doing much of anything (i.e. not advancing the timing) except causing the stalling so we left it out. I was gonna grab a computer out of the junkyard but never got around to it, the truck had other more important problems.
Old Jan 1, 2001 | 11:38 AM
drh2810's Avatar
drh2810
Stalls
There are two relays on the driver side fender well. Both appear to be original equipment. I cleaned all connections.
I have yet to check the computer.
Thanks.
Old Jan 1, 2001 | 10:29 PM
hotrodford_88
Stalls
I would have thought that if you pulled the computer out & left it out, the truck wouldn't run without it.
Especially since it controls all of the fuel injection, not to mention everything else on the engine.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
[link:www.geocities.com/westlake_vfd/Westlake.html|Westlake VFD Website]
Old Jan 1, 2001 | 11:12 PM
mjb007's Avatar
mjb007
Stalls
[font size="1" color="#FF0000"]LAST EDITED ON 02-Jan-01 AT 00:18 AM (EST)[/font][p]
yes if it was EFI.
85' carb
all i can figure was that it did was the spark timing. everything else still worked when the computer was removed.
what clued us in to that was that when a diagnostic module was plugged in it would make a continuous beep. I don't know of any other way to test the computer.
actually my post didn't really matter, i didn't realize that partway thru we switched from the '82 f-150 to an '88 bronco.
Hulltech41
Feb 16, 2015 06:38 PM
TheKirbyMan
32
Aug 26, 2012 10:02 PM
Old Brown Truck
Electrical Systems/Wiring
Jun 17, 2009 10:57 PM
pikiluvi
20
Sep 21, 2004 07:09 PM
Njbmx
Apr 12, 2002 11:01 PM
