83 stepside lariat
Old Apr 7, 2005 | 02:14 PM
83stepside32784's Avatar
83stepside32784
83 stepside lariat
hi all i will appreciate all the info you can give me.
heres the prob i have a 1983 F-150 lariat step side and the rear brake lights and turn signals work but r very dim and are not visible during the day and the tail lights dont work at all please help i need this truck on road soon my 2000 F-150 only has 2 gears and has to be fixxed thanx in advance
kevin parker
Old Apr 7, 2005 | 04:36 PM
mudgepondexpress's Avatar
mudgepondexpress
Easy,
The ground from the bed to the frame is bad. Same thing happened on my 1981 Flairside. I just made a ground wire from the frame to somewhere on the main bed metal (not the strips!).
They will brighten right up. Try it quick with a jumper wire from the light mount to the frame.
Kenny
Old Apr 8, 2005 | 10:49 AM
83stepside32784
thank you so much ill let you know if it works
thanks again
kevin parker
