Dumb brake question
Old Apr 7, 2005 | 01:53 PM
myke's Avatar
myke
Dumb brake question
'97 E150 5.4 -
My front rotor is kind of dinged up & I want to replace it. What's involved? Do I just pull off the wheel & caliper & start yanking, or do I need to remove the grease cap, castle nut, bearings, etc.?
Thanks.
Old Apr 7, 2005 | 06:41 PM
Fordcr's Avatar
Fordcr
yup, caliper, grease cap, cotter pin, castle nut, bearing-- now rotor off. If you are changing the rotor you may want to put your bearing races in the new one. If it is apart this far it is a good time to repack bearings and change grease seal on the spindle side. Be sure to preload bearings.....better yet buy a Haynes and or Chiltons repair manual. and be sure I didn't miss anything!
