Good Heads
Old Dec 21, 2000 | 07:58 AM
Motorcraftsman's Avatar
Motorcraftsman
Good Heads
Old Jan 4, 2001 | 11:02 PM
redtruck's Avatar
redtruck
Good Heads
Are all 302 heads the same? I want to use some good heads from a 1980 carberated 302 on a 1986 EFI 302, will this work? Do all 302 heads have all of the needed bolt holes for the brackets? I know some heads dont have the smog pipe holes, are there any other differences. Thanks
Old Jan 5, 2001 | 12:13 PM
ecarter50's Avatar
ecarter50
Good Heads
They should fit I have a 77 302 converted to 85 F150 EFI everything bolted on.
Old Jan 5, 2001 | 02:48 PM
78 bronco owner's Avatar
78 bronco owner
Good Heads
You'd be better off with '87 up heads. Much better overall performance. The E7's ('87's and up) and the newer GT40's are very good heads and not overly pricey...
