Trans temp fues
Old Apr 6, 2005 | 03:24 PM
good 'ol ford's Avatar
good 'ol ford
Trans temp fues
hey im putting a perma cool transfilter and temp gage on my c6. there is a inline fuse that comes with the kit but the directions say nothing about it. has anyone ever used this kit or do anyone know where it is suposed to go. thanx in advance
Old Apr 13, 2005 | 11:30 PM
good 'ol ford
ok i guess no one had ever done this b4
Old Apr 14, 2005 | 02:23 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Fuse? New to me. I have a remote spin-on filter that's mounted inside the right frame rail, no electrical for a fuse. I'm running thru the radiator cooler then a cooler between the frame rails to a spin on filter then return to the trans. Magnet in the trans and spin on. Please explain more.
Carl....=o&o>....
Old Apr 14, 2005 | 02:33 AM
"Beemer Nut"
Sorry I had a senior moment. Right after your power pick up point you should add a inline fuse that is easy to access and protection. With a cast TCI aluminum pan and cooler a trans oil temp gauge wasn't necessary in my application. The temp probe should be threaded into the pan.
Carl....=o&o>....
Old Apr 14, 2005 | 11:07 AM
good 'ol ford
hey thanx for the info.
