Sponsored by: Real Truck
Mpg Advice
Old Apr 7, 2005 | 09:58 PM
whalerron's Avatar
whalerron
You cannot simply shutdown a cylinder without changing the software in the computer too. Each and every time the computer thinks a cylinder should have fired, it checks the crank position sensor and looks for crank acceleration. If that acceleration isn't seen, the fault will be recorded as a misfire and after a few of these your check engine light will come on. When that happens, the computer will start trying to accomodate a problem which it interprets to be an ignition misfire problem.
You also cannot monkey with the timing because the computer will readjust it to where it thinks the timing should be.
If you do start messing with this, be darned sure that you keep fuel from getting to that cylinder. That fuel will get routed right out the exhaust valve and down the pipes to the catalytic converter. Unburnt fuel running through a cat will destroy the converter.
Building_Fords
Dec 22, 2016 03:53 PM
Claybreaker144
Apr 17, 2016 08:02 PM
Jafo56
Apr 3, 2016 02:14 PM
F-WhiteThunder
Jan 10, 2016 12:33 PM
Rooster Rancher
Nov 3, 2014 12:39 PM
