Backfire: What are the main causes
Old Jan 7, 2001 | 09:20 PM
Koepke's Avatar
Koepke
I have a 83 f150 with a 351w and it is backfiring all the time, and lossing power.
What are the main causes of backfiring
Old Jan 8, 2001 | 12:36 AM
PAUL_2's Avatar
PAUL_2
Basically all a backfire is the explosion that would normally be contained within the cylinder isnt being contained . When exactly does the backfire occur ?
Old Jan 8, 2001 | 06:56 AM
TallPaul's Avatar
TallPaul
I recall a backfiring truck at the auto shop I go to. Turned out the guy had put a new set of plug wires on and got a couple of them crossed up. I assume one was firing near the end of the exhaust stroke when all the fresh fuel air mix was being pushed down the exhaust pipe. A wonder it didn't rip his muffler open.
Old Jan 8, 2001 | 07:29 AM
rudedog's Avatar
rudedog
When does it backfire/
All the time or under power
It could be a number of thing (i.e.) plug wires, valves sticking, timing chain slack,
But when you do find the problem be sure to replace the power valve in the carb, when you back fire into the carb there is a tendancy to blow these out.
Let me know.L8TR
Old Jan 8, 2001 | 09:59 PM
Koepke's Avatar
Koepke
The backfirring seems to be mainly when under a load.
Old Jan 9, 2001 | 06:18 PM
nwp's Avatar
nwp
If it's old enough to need new plug wires, or you don't personally know how old they are , change em with good ones -(lifetimers - or something like that. Myterious misses, backfires, etc under loads seem to show up more with older wires -that way you isolate the problem more and it's good insurance for the future. Sometimes by running it in the dark you can get a glimpse of some sparks around the plug wires when you rev it.
Old Jan 9, 2001 | 06:31 PM
jules's Avatar
jules
