Can someone tell me please, are the brackets that supprt the motor/mounts, that fix to the frame the same in all 4x2 trucks or do they differ for different motors?as they have been removed from my truck and i need to replace them.Thanks.
smokin tail pipes, There is one set of perches that will fit FE and inline 6, there is another set that fit small block, there is another set that fits 429/460. I'm not sure if the 351M/400 is the same for any of the others or not, but I know for a fact there are at least 3 different sets.
Mike
It sounds as if you already came to this conclusion, but perches are common to M-blocks (your 400) and 302 powered trucks, however the actual mounts are different. I don't know about the FE's, but looking at the other posts, it appears they're different.
Hope this helps, you might poke around on Ebay for someone to mail a pair your way?
