timming question
Old Apr 5, 2005 | 10:25 PM
thecowboy's Avatar
thecowboy
timming question
just wondering what should i set my timming to on my 1980 F-100 with the 300 to get all the power i can without all the spark knock? or just run high test gas in it? i think its like 14 before TDC right?
thanks alot,
thecowboy
Old Apr 6, 2005 | 12:37 AM
optikal illushun's Avatar
optikal illushun
12-14 should work fine. if it pings back it off one degree or so.
Old Apr 6, 2005 | 01:02 AM
GregTruck's Avatar
GregTruck
While were on the subject. What is the best setting for a 300 set up in a 65 F100? I say set up in because it is a 75 or so engine with, for now, the original Autolite carb and point type ignition. I think I have it set at around 8. Let me rephrase my question. What is the best setting for mileage? Forget power. I'm talkin' MPG. Anybody feel my pain?
Old Apr 6, 2005 | 03:04 PM
savage066's Avatar
savage066
greg, i'd go with 4-6 deg BTDC...that's where i set mine last and i get about 19 mpg.
Old Apr 6, 2005 | 11:24 PM
GregTruck's Avatar
GregTruck
Wow! 19, thats a good number. I don't have any light now but I could probably just turn the distributor a tad and be within that range. I'm still debating on how much better a Carter YF will be than the original Autolite 1100 carburetor. As soon as I got fed up with the Autolite and bought a Carter the Autolite has performed fine. Many say that the Carter upgrade is not only more reliable but economical as well. I want to do anything I can to get better mileage and make it reasonable to keep my truck on the road. I probably should get a Pertronix for the ignition as long as I am talking economy. Lots to think about....
Old Apr 7, 2005 | 12:28 AM
rhetor's Avatar
rhetor
factory timing should be 10*.
Most of us are getting good results at about 13 without any ping.
Old Apr 7, 2005 | 12:45 AM
GregTruck's Avatar
GregTruck
Now I'm more confused than ever Rhetor says up to 13. The factory evidently says 10. Savage says 4-6 and gets 19 MPG.
Upsideundersidewaysdown... Yeah, Thats the way to go
Old Apr 7, 2005 | 01:24 AM
optikal illushun
factory is 10, usually best performance is 13, not sure bout the 4-6...
Old Apr 7, 2005 | 06:23 AM
savage066's Avatar
savage066
factory for mine is 6...it's a 79
Old Apr 7, 2005 | 07:06 PM
Psyte's Avatar
Psyte
13 degrees? is that with regular 87 octane?
Old Apr 7, 2005 | 08:57 PM
optikal illushun
should be with 87 octane. rememeber elevation also comes into play here.
Old Apr 7, 2005 | 10:35 PM
dgpruitt's Avatar
dgpruitt
GregTruck,
My '65 shop manual says 6 BTDC is the standard timing for 240/300. That's what I'm currently running with my stock 240 (autolite 1101, loadomatic distributor).
Power is OK, not great, particularly heading up long steep grades. I have a slight off-idle stumble. I am also occasionally seeing the flood problem, where the carb is flooded for about 10-15 minutes after shutdown.
I am currently averaging only about 12 mpg.
I have EFI manifolds and walker downpipe, but haven't installed them, yet. I'm hoping this will help a little at least on the mpg.
Old Apr 8, 2005 | 11:23 AM
Red77F100's Avatar
Red77F100
My '77 shop manual says the factory setting was 10* +/-2* for the 300 that year. Mine idled poorly at 10*, so I bumped it up to 12* and it's great now!
Unfortunately for me, the stock type distributor is fubar'd and the mechanical advance is pulling at 1300RPM, and the vacuum is kicking in whenever it feels like it. I think I need a better distributor....
Old Apr 8, 2005 | 11:45 AM
FordF150Fixer's Avatar
FordF150Fixer
In my opinion, there is no one “correct” setting for timing. The factory timing is a compromise that works reasonably well in many parts of the country. For best economy and performance, timing should be set to allow for your driving style, quality of gas, local weather, altitude, ect.
The best timing for my truck with regular gas in the costal plains of Virginia is going to be different from a truck in Denver. I set my timing with a vacuum gauge. I adjust the distributor for maximum vacuum at idle then retard slightly to eliminate knock.
Maybe some of the more experienced forum members will chime in and let me know if I’m too far off base on this topic.
Old Apr 8, 2005 | 12:56 PM
rhetor's Avatar
rhetor
FordF150Fixer, this is a common method of adjusting timing. Its a great way to do it on 300s being that its hard to trust the damper with all this internet conspiracy going around about it slipping...
