Sponsored by: Real Truck
Rear Sliding Window
Old Apr 5, 2005 | 08:35 PM
Rongold's Avatar
Rongold
Question Rear Sliding Window
Has anyone ever replaced their fixed position rear window with a manual sliding one ??? How hard is it, and what seals it against the elements ??? The truck is a 2003 F-250 regular cab.
RON
Old Apr 5, 2005 | 08:42 PM
resqpink's Avatar
resqpink
I did on a Toyota in about '88. I takes two people, but it's easy. The rubber seal around the outside protects it from leakage! You wrap a string around the seal of the new window and pull it inward while someone presses the window in place from the outside. This pulls the inner part of the seal/window in place.
Old Apr 6, 2005 | 12:26 AM
texan2004's Avatar
texan2004
If you have a mobil glass guy do it, the cost installed may be as cheap or less than buying one somewhere and doing it yourself. Worth checking into.
