Sponsored by: Kumho
leveling kit price
Old Apr 5, 2005 | 06:10 PM
andym's Avatar
andym
leveling kit price
A 4x4 shop around here quote me $369 for the superlift 2wd leveling kit. Plus shocks.
Does that sound as steep to you as it does to me for a pair of springs and some alignment cams? If I go to a spring shop and get some slightly longer springs made (+1" from factory height) can I get away with using the factory cams? Or what about using a set of F-250 coils instead?
Old Apr 5, 2005 | 06:23 PM
SRD4X4's Avatar
SRD4X4
Ballpark (where I'm at) $100 for heavier MOOG springs,$50 for camber sleeves,$60 labor to install springs,$65 for installation of inserts and alignment.The factory camber sleeves are non-adjustable,the after market one's are,so it's kinda a one shot deal.Once there in you will have future adjustment if needed.Labor for shocks should be included with the spring install since they are half way out anyway.
Old Apr 5, 2005 | 06:37 PM
andym's Avatar
andym
Ok. I plan on doing the work myself (it's cake) so we can scratch all the labor charges. So the factory sleeves in a 2wd are non-adjustable? Hmm.. that's different than the 4x4's. I didn't know that. I plan on getting a lifetime alignment at Firestone anyway, so that's a moot point. I know it will need alignments from now until the end of eternity anyway.
Where do you get Moog springs from?
Old Apr 5, 2005 | 06:49 PM
SRD4X4's Avatar
SRD4X4
Any parts store should able to get them for you.CC-844 will give you between 2 1/2-3'',CC-822 or 824 should give 2'' without beatin' you to death.But those #'s will vary some depending on how worn your current springs are.The factory camber/caster sleeves have a "boss" made into them that lines up with the "pinch bolt" in the axle which prevents them from being adjusted.The 844's are for a F-350 diesel with A/C,the #'s go down from there as far as application,if that helps you.The price on the springs will vary (I think) as to location.Retail where I'm at is like $120,cost is like $80 a pair.
