Expedition TCIL switch Problem
Old Apr 5, 2005 | 05:52 PM
rapturez's Avatar
rapturez
Unhappy Expedition TCIL switch Problem
I have a problem with the TCIL....
Mine does blink...
My truck runs good if I turn off the overdrive.(light on), but if I run it with the overdrive at deault, it does not switch gears right. As soon as I take off, 1-2 gear is rough. Like a hard push, then 2-3 same thing. After that it rides ok. The TCIL won't flash until I go over 50-55mph and then slow down to 30-20 or complete stop. After I stop, the light flashes and i get to that hard push. I can turn the truck off and start it, problem goes away, until I get past the 55mph limit. Any suggestion?... where should I check?... what should I check?...
97 Expedition
4x4 Eddie Bauer
80k
