HELP I need to be educated
Old Apr 6, 2005 | 12:14 PM
  #31
fatfenders's Avatar
fatfenders
Originally Posted by Jag Red 54
Hiball: When I first bought my Fairlane (1993) it had a 12-6 battery in it. They are sold after market. They start on 12 volt, then change to 6 volt to run your lights, etc. Very pricey and only good for about a year, but the starter motor never gave me any problem. (I think these batteries only last a year because they are only being charged at about 7 volts off the stock generator) Jag
JAG
If you wanted to hassle with the dual voltage, I would think a pair of six volts would be a better option. Be easy to mount the additional battery on our trucks anyway. Most military systems use either dual, or quad batteries. Fairly easy to series or parallel them as needed to get the desired voltage.
Lot of good info on this thread. Thanks.
Old Apr 6, 2005 | 04:55 PM
  #32
Jag Red 54's Avatar
Jag Red 54
Dewayne, I see that you have come to the same conclusion that I did..... after about two years!! The gimmick is unnecessary. I had bought the 55 from a guy who claimed that it was hard to start. So he had bought this 6/12 to spin the motor faster. However, as the battery got older and needed to be charged, the solenoid on top had to be disconnected once in a while. It would just click when you turned the key. So I learned that if you disconnected a wire on the battery solenoid, then the starter would turn on six volts and the engine would start. So it dawned on me finally, that since the engine started without the 12 volts; why not convert back to the standard 6 volt battery? Thats what I did and it has never had a hard time starting. Jag
Old Apr 6, 2005 | 05:04 PM
  #33
Christopher2's Avatar
Christopher2
Veteran: Navy
I am doing it for the brighter lighting. I have driven older vehicles with a 6 volt system and the lighting didn't cut it for me. My truck starts just fine on 6 volts. I would like the good halogen lights, but I don't think the 6 volt generator would. Beyond that I am good.
Old Apr 6, 2005 | 05:09 PM
  #34
Christopher2
Veteran: Navy
Speaking of dual batteries, will the V8 battery tray fit in the 6 cylinder? In the correct spot for a V8 on the passengers side?
Old Apr 6, 2005 | 05:14 PM
  #35
fatfenders's Avatar
fatfenders
Christopher
Check out the tech article on brighter lights. It works well for cheap. Not sure what GA your stock light circuit is (surely it needs an upgrade anyway). I ran 12GA, but 14GA should be suffiicient. Don't neglect your headlight switch either. I've seen a few of those melt down over the years. I wouldn't use a 50 year old switch under any circumstances, especially with halogens.
Old Apr 6, 2005 | 06:10 PM
  #36
Christopher2
Veteran: Navy
I am going to use relays for the headlights and use the factory switch to control the relays.
Originally Posted by fatfenders
Christopher
Old Apr 6, 2005 | 07:48 PM
  #37
AXracer's Avatar
AXracer
One only has to look under my dash and hood to see the result of using old and chopped up wiring. Strange thing is they just replaced the burned wires and left the rest of the rat's nest in place??? ( see the before pics in my gallery for what NOT to do!)
Old Apr 7, 2005 | 08:40 AM
  #38
hiball3985's Avatar
hiball3985
and for people who don't want to deal with wiring and possible fire problem, you can buy a new truck with the problems already installed at the factory...........LOL
Old Apr 7, 2005 | 12:30 PM
  #39
fatfenders's Avatar
fatfenders
Now that you mention it, I have purchased a total of 3 new vehicles in my life. All three were recalled for an electronic fire hazard.
Christopher
I wasn't clear but that's what I actually meant. That is how I am using my headlight switch too.
Old Apr 7, 2005 | 07:44 PM
  #40
57_ford's Avatar
57_ford
Don't they make 6 volt halogen headlights?
On your first post. Found this in a electronics book glossary
watt (w) The unit of power in the metric system. The watt describes how fast a circuit uses electrical energy.
It seems to me that heat is just wasted energy.
Old Apr 7, 2005 | 09:27 PM
  #41
Christopher2
Veteran: Navy
That is correct to a point. An electric heater warms your house so it is not wasted energy. Same prinicpal as an electric hot water heater.
wavetrain75
Dec 17, 2012 08:57 PM
Cruiseomatic
Electrical Systems/Wiring
Aug 7, 2011 07:22 AM
QUINCE
Nov 6, 2008 10:40 AM
04F-250 stroked
Jun 21, 2007 09:41 PM
SShank42
Apr 2, 2005 01:43 PM
