Big Front Disc Brakes
Old Apr 5, 2005 | 10:39 AM
Jaysouth2000's Avatar
Jaysouth2000
Does anyone know any manufacturer that makes a big front disc brake kit for the ford trucks 73-79. If not how about crossdrilled hub/rotor? Aftermarket Calipers. Anything besides the stock plain jane. I have been bugging SSBC to make something for the 73-79 truck.
Old Apr 5, 2005 | 10:54 AM
beartracks's Avatar
beartracks
You can get significant improvement by using good parts such as drilled and sloted rotors and powder coated calipers (steel pistons) from NAPA under the United line. On my rig I also intend to replace the rubber lines to the calipers with braded but need to find some extened lengths for 2 wheel drive.
Old Apr 5, 2005 | 02:15 PM
GeneStoner's Avatar
GeneStoner
If you are going to run drilled/slotted rotors, keep in mind that though the brakes might cool better, the actual swept-area of the disc is lessened by having slots/holes drilled into them. This provides less area in which the brake pad has to grab onto the disc. To combat this, you must use a larger disc to offset the loss of material on a drilled/slotted disc.
Galloping_Ghost
Mar 24, 2009 07:48 PM
BrentKasson
18
Feb 17, 2005 02:10 AM
thesprocket26
Aug 28, 2004 03:46 PM
StockMan
Nov 19, 2001 10:41 AM
