serial number help
Old Apr 5, 2005 | 07:09 AM
bigred00's Avatar
bigred00
serial number help
Need help in locating my engine serial number on my 2000 7.3! Thanks in advance
Old Apr 5, 2005 | 07:17 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 5, 2005 | 07:40 AM
Robbgt's Avatar
Robbgt
Welcome to FTE!! The serial # should be on the driver side valve cover.... if it's not... then you can find it under the truck stamped next to the oil filter on a machined piece of metal.... you may need to use a wire brush to clean it off so you can see it (i had to on mine)... again welcome to FTE!!
-Robb
