Coolent system flush and fluid?
Old Apr 5, 2005 | 02:10 AM
rshissler's Avatar
rshissler
whats the best way to flush the coolent system on a 84 300 I6 bronco and what type of fuild should i replace it with??
Old Apr 6, 2005 | 11:56 AM
73Custom's Avatar
73Custom
I like to pull off the rad hoses and heater hoses (one end is enough), and remove the thermostat. Then use a garden hose and flush water through the radiator, engine and heater core from both directions until the water coming out is clean and clear. Then replace the thermostat and reattach hoses (replace if needed) then fill with 50/50 mix of antifreeze and water. Then run it up to full operating temp (make sure it doesn't overheat), then check the antifreeze level when it's cooled down. And check the antifreeze level for the next couple days.
This is also a good time to use the sprayer on the garden hose to spray out the radiator fins, they get full of dirt and bugs and reduce cooling.
Marty
Old Apr 6, 2005 | 04:54 PM
rshissler's Avatar
rshissler
how would u flush water though the heater core?
Old Apr 11, 2005 | 01:52 PM
73Custom's Avatar
73Custom
Sorry it took me so long to get back... The two small hoses go to the heater core. So use the hose to run water in one heater hose and it will go through the heater core and out the other hose.
Marty
Old Apr 11, 2005 | 02:53 PM
rshissler's Avatar
rshissler
lol figured thats wht u did just wanted to make sure
