CD burner trouble
Old Apr 4, 2005 | 11:13 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
CD burner trouble
Hey all. Trying to burn an MP3 disc for my wife. Didn't work out so well. Went through 3 discs and every time the burner software spits it out, saying the disc is damaged. Tried a 4th one in "normal" non MP3 format, and that one got spat out too.
As far as I know, it's a HP burner. I've tried with HP Record and Music Match, both of them won't burn nothing. I'm using Memorex CD-R. But, I'm suspecting it's the burner itself, as we've always had trouble with the thing.
Is there a way I can check the burner, or clean it, or something short of replacing it?
If I do have to replace it, will a DVD drive also burn CD's?
Old Apr 4, 2005 | 11:37 PM
haroldservice's Avatar
haroldservice
just checking, but is the disc an audio or data?
websthes's Avatar
websthes
did you put the blank disc in right side up?
will it read a disc you know is good.
a dvd burner can also burn cds but last time i checked they're expensive.
those burning programs are tempermental. i manage with nero though.
Old Apr 5, 2005 | 12:37 AM
nightowl_52's Avatar
nightowl_52
It doesn't matter if it's audio or data CD it should burn to either. Does it read data CD's ? does it read and play prerecorded music CD's ? Have you tried playing any CD with mp3's already on it ? if yes, then It sounds like the firmware drivers are not installed or corrupted which will not allow it to be seen as a burner by windows but just as a standerd CD drive. If you want to check to see if your firmware drivers are installed go to nero's site and download their CD Info Tool program. It will tell you all about your drive. If all else is ok, then the drive might be bad.
Old Apr 5, 2005 | 12:56 AM
bigrigfixer
The Pacifier
I don't do much in the way of actually playing cd's on my computer. In fact, I haven't loaded much into it. The last thing I loaded was some Canon photo printer software. My wife and sister in law use Printmaster a lot. And our wedding pictures are on cd.
For all I know, it could be just the music that it's having a problem with. I've made some picture cd's with no problem in the past, but I haven't tried lately. The last time I burned pictures was probably last year some time, before we got our picture printer. The last time I attempted a music cd was about a year and a half.
I'll try a picture cd in the morning and let you know how it goes.
Also, is there a way to clear a CD-R, even though there's nothing on it? If I try to read the 4 cd's, it's unreadable (ie blank) but they won't take any more data.
Old Apr 5, 2005 | 03:23 AM
furball69's Avatar
furball69
I bought a box of blank cd's once and tried four of them and they were all bad, never had a problem before that, took the discs back and exchanged them for another brand and all was good.
I've also had problems with HP burners. Is it a 2x4x8 by any chance? They were notorious for having bad springs in the lens focusing mechanism. I believe there was a class action suit over it.
Another unit that was in a very dusty area had the lens fouled up by dust. Quite a job to clean the lens by taking the drive apart and cleaning it with a q-tip. Not a job for the faint of heart.
DVD burners are pretty cheap. You should be able to get one for under a hundred bucks CDN. I'd recommend an LG unit.
Old Apr 5, 2005 | 09:48 AM
Violjohn78's Avatar
Violjohn78
One thing to look at, is how fast is your burner, and what speed are your disks rated at? That can cause all sorts of read errors.
Old Apr 5, 2005 | 10:14 AM
bigrigfixer
The Pacifier
Well, I tried making a picture CD. That one got spat out too. I wish I could remember where I got these blanks. We only got them a couple months ago. So from a 10 pack, 5 are now no good.
Is there a way to clean the lens without totally taking the drive apart?
Old Apr 5, 2005 | 11:16 AM
mikebon08's Avatar
mikebon08
I had several HP writers....the only one I was happy with, and the only one I still have, was the first one, a 4/4/24 actually made by (I think) Teac. The others all went bye-bye as quickly as I could replace them. I think the worst one was the last one, supposed to be a 24/10/40 but couldn't run more than 10-12X or it made coasters.
For the amount of trouble...I'd get a new writer. I use Sony cd and dvd-writers, have had no trouble with any of them. Sony DVDRW is $60 US....$80-90 CD?
Old Apr 5, 2005 | 11:22 AM
haroldservice
i can't write music sucessfully to data cd's, and my burners work great. there are lens cleaners available, dry and wet. any store that sells music or computer gear will have them.
Old Apr 5, 2005 | 01:43 PM
nightowl_52
I can't understand that one. I have a couple of hundred mp3's on data CompUSA CD-R's and CD-RW's. It's possible that the disks are bad, but five out of a ten box is unusual. He could try a different brand and if the problem still persists then I'd look at the drivers. CD cleaner disks only have little brushes on them to sweep off the lens. If the lens is dirtier then that, then the drive has to be opened, and like furball sez, it's not a job for a novice to do. Usually if the lens is clean enough to read the disks, it should clean enough to write to them. bigrig, if you know what brand and model # that burner is, go to their website and download the drivers for it and reinstall them. Then see if it starts working again.
Old Apr 5, 2005 | 01:57 PM
haroldservice
will the data cd's not take music for play in regular cd players? i have to use audio cd's to write music to. regular ones sre a lot cheaper, sure would be nice to cut costs somewhere.
Old Apr 5, 2005 | 02:15 PM
tony b.'s Avatar
tony b.
cd
No Im pretty sure if you burn music on a dat cd you will only be able to play it on your computer only!
Old Apr 5, 2005 | 03:08 PM
haroldservice
so maybe my burner programs are old, in that i cannot get music onto data cd's?
Old Apr 5, 2005 | 03:42 PM
rangerxlt02's Avatar
rangerxlt02
You can burn music on data CDs. Don't bother getting audio blanks. Your burning software should be fine (been burning onto data CDs for years now).
It is probably one of two things:
Your burner is bad
That lot of blank CDs you got is bad
To troubleshoot, go buy a pack of some blank CDs. Do they work? If not, then it is probably the burner itself.
