Tach help
Old Apr 4, 2005 | 10:46 PM
Biggcountry's Avatar
Biggcountry
Cool Tach help
I have an 80 F150. I just bought a Sunpro 2 tach for it and I can't get it to work. I know it's not the tach cuz I tried another one and it did the same. I hooked the green wire to the coil -, the red to the power and the black to the ground. So whats the problem? Help me out!!!!!!!
Old Apr 5, 2005 | 12:49 AM
yozsi's Avatar
yozsi
you sure you have the correct wiring diagram.
Old Apr 5, 2005 | 12:58 AM
pfogle's Avatar
pfogle
Are you sure it was the - side of the coil? Was the factory color green or tan/yellow? Is the coil grounded well?
Old Apr 5, 2005 | 03:20 PM
Biggcountry
It is on the negative side. And I looked at several websites for instructions and they all said the same thing. The truck runs fine so the coil must be good. I just didn't know if there was another way of doin it for pre 85 models. The instructions only went back to 85. Or There might be a wire cut or loose somewhere I just don't know where to look.
