Speedo Gear
302, AOD, 4.10:1 and 33" tires
I found a formula on the net. I think the tailshaft has 8 teeth.
(tailshaft teeth*rear axle ratio*20.2)/ tire diameter = teeth required
(8*4.1*20.2)/33 = 20.07758
So should I get a 20 tooth gear and where can you get gears?
