weird
Old Apr 4, 2005 | 07:35 PM
mannyj's Avatar
mannyj
Angry weird
i have a 92 f-150 4x4 . it smokes but only after it warms up to normal operating temp. so i pulled the plugs and 1,4-8 are fine but 2 and 3 are soaked with gas.i put some fuel injection cleaner in and that didnt help it only made it worse. can anyone tell me what the problem may be
Old Apr 4, 2005 | 09:57 PM
92supercab's Avatar
92supercab
Any chance the plugwires are reversed. It sounds like they are not sparking. Also check the cap for corosion.
Old Apr 4, 2005 | 10:09 PM
frederic's Avatar
frederic
Probably the fuel injectors are stuck open in those cylinders. I'd switch them to another cylinder and see if the "soaked with gas" problem moves with the injectors.
Old Apr 5, 2005 | 10:40 PM
mannyj's Avatar
mannyj
its got a new cap and rotor so i dont think that is the problem i will check the firing order and make sure that its right and i will also move the injectors around and see what i get thanks for the help guys
Old Apr 6, 2005 | 08:40 PM
mannyj's Avatar
mannyj
checked the firing order to find the plugs in 2 and 3 are no good. going to replace and try some more just to make sure thats the problem
Old Apr 6, 2005 | 09:02 PM
tex94F250's Avatar
tex94F250
When done run some Seafoam through the top end to de-gum it and the injectors.
Ford Man Since Birth
Offroad & 4x4
Nov 12, 2011 04:00 PM
mikedeason
Sep 17, 2007 09:04 AM
Savage1
Jan 13, 2006 12:24 PM
4wheelFordfan
Oct 20, 2005 08:07 PM
fordman311
Offroad & 4x4
Aug 16, 2005 12:17 PM
