Battery Question
Old Apr 4, 2005 | 11:04 AM
langbone's Avatar
langbone
Battery Question
Hi guys,& I guess(gals) . I'm a new member here, although I have been lurking for quite some time. I'm getting ready to change the batteries on my 2000 F 350. Is there any particular sequence I should follow. IE disconnect them one at a time, or both together. Does it make any difference wether you disconnect the drivers side or passenger side first. Thanks in advance. George
Old Apr 4, 2005 | 11:23 AM
slc10844's Avatar
slc10844
Disconnect both negative terminals first. They are also the last thing to hook up. Make sure they are tucked away so the don't touch the negative battery post while you are working on the replacement. Once both negative cables are disconnected you can replace the batteries any order you want.
