Still using the Push Button Start?
Old Apr 4, 2005 | 10:34 AM
Huntsman's Avatar
Huntsman
How many are still engaging the starter by way of the stock push button? I'm doing a variation on the original and will be using the original key switch; still think it's pretty neat and a throw back to earlier times.
Old Apr 4, 2005 | 10:38 AM
55Bubba's Avatar
55Bubba
I use the buton cause my kin ain't smart enuff to figur hit out. keeps em frum borrerin my truk if I dunt want em to. Ain't I smart?
Bubba
Old Apr 4, 2005 | 10:57 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
I still have mine and plan to continue using it.
Old Apr 4, 2005 | 10:58 AM
Jag Red 54's Avatar
Jag Red 54
No, I switched over to the 56 switch and the starter button became the horn button. aOOOOOHGGa Jag
Old Apr 4, 2005 | 11:11 AM
theGman's Avatar
theGman
Dittos with the horn button conversion; mine became a bull horn (on both trucks).
Old Apr 4, 2005 | 11:17 AM
fordcountry's Avatar
fordcountry
I still use the push button and plan to keep it this way. I like it!
Old Apr 4, 2005 | 11:19 AM
jvmcc's Avatar
jvmcc
I'm switching over to a button. Just for the nostalgia.
Old Apr 4, 2005 | 11:37 AM
48fordjeffie's Avatar
48fordjeffie
Smile Still using the Push Button Start
I am also using the starter button. I am not changing mine either, I think it is a part of the charm of driving a 57 year old truck!!
Old Apr 4, 2005 | 12:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I just went to a gear-reduction starter on my flatty, and it is like the GM starters, has a solenoid on the starter. So I use the starter button to energize the stock Ford starter solenoid, which just sends the start signal to the starter solenoid on the starter. (Confusing?!) So the stock solenoid is handling a couple of amps, instead of the whole starter load. Works slick and looks stock.
Old Apr 4, 2005 | 01:17 PM
51dueller's Avatar
51dueller
I'm still using the starter button. I went to the later 53-55 two pole button because it's was hard to find a 12v solinod that to activate you had to ground.
Old Apr 4, 2005 | 03:04 PM
51ford fan's Avatar
51ford fan
I use mine to operate the selnoid to open the drivers door.
Old Apr 4, 2005 | 03:19 PM
4tl8ford's Avatar
4tl8ford
I intend to use 2, one out of sight the also has to be pushed to complete the circuit.
Old Apr 4, 2005 | 03:37 PM
Jeff55F100's Avatar
Jeff55F100
I'm glad this what brought up. I too intend on using the push button starter. My concern is I will be running a 12V system, and the button, ignition switch etc. is original 6V. Does this pose a voltage problem (frying the wireing, button, switch)? What is the solution to this dilema?
Jeff
Old Apr 4, 2005 | 03:51 PM
fatfenders's Avatar
fatfenders
Jeff
Shouldn't be an issue. You are just breaking and restoring continuity. Voltage doesn't matter. In fact incresing to 12V should be less stressful on the button I would think.
I will never remove mine, the button is part of what makes a 50s Effie what it is to me.
Old Apr 4, 2005 | 04:56 PM
abe's Avatar
abe
That a boy, Fenders, slowly we are getting you back to the Light Side! I am glad to hear you are keeping the starter button!!
abe
