Door Open Light will not go off?
Old Apr 4, 2005 | 09:55 AM
billyboy's Avatar
billyboy
Has anyone had this problem and what did they find wrong. It doesn’t happen all the time, but sometimes the Door open light will stay of when I am driving. I get out check all the doors and they are all closed tight. The light will not go off. Then all of a sudden the next time get in and go it’s off. Any input would be great. Thanks
Old Apr 4, 2005 | 11:10 AM
Daryl Hunter's Avatar
Daryl Hunter
Had a problem like that in my '98 F-150. It was a door switch that had to be replaced.
Old Apr 4, 2005 | 11:34 AM
PAN's Avatar
PAN
Mine did it twice when it was really cold out. I just washed it and I think water froze somewhere. Cause when you would shut a door the dome lights and doorlight stayed on. The next day it was usually ok
Old Apr 4, 2005 | 12:54 PM
yellowducman's Avatar
yellowducman
Seems to be a common problem with the fords. I have had 2 trucks (97 F150 XLT and 2000 F250) and they have both have done it. I bought some time by spraying the latch area with WD40 but when it was all said and done I had to replace the switches.
Old Apr 4, 2005 | 12:57 PM
billyboy's Avatar
billyboy
thanks Guys.. I'm due for a Oil Change so i will tell the dealer i need a new switch.
Old Apr 4, 2005 | 02:01 PM
Antacus's Avatar
Antacus
My old '08 Ford Ranger had this problem. I just sprayed some white greese in the door latch (latch is also the sensor), opened/closed the door a dozen times, 1 more squirt for good measure, and that fixed the problem. That was about two years ago and it has not acted up again.
