rear main seal question
Old Apr 4, 2005 | 07:52 AM
oldbird1965's Avatar
oldbird1965
I bought a rear main seal from international and it contained the seal, ring and housing. Also a tube of RVT was included so I thought I was all set. Went to install it now I'm confused. The directions say to put Loctite Hydraulic sealant on O.D. crankshaft flange. Then the next set is to put a bead of RVT (included) around seal retainer ring. My question is, what is this Loctite Hydraulic sealant? Can I use the RVT around the crank to seal the ring or should I get the Loctite stuff? Thanks
Old Apr 4, 2005 | 08:24 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
All you need is the RTV.
