Ignition timing
Old Apr 4, 2005 | 04:11 AM
csft's Avatar
csft
Ignition timing
1996, F250HD, 351W.
The under hood sticker says that the timing is not adjustable.
I put a light on it, loosened the distributor hold down and advanced the timing.
It had 18 degrees at idle, It is now 22 degrees at idle and runs a whole lot better.
Does anyone know what it is supposed to be and the proper way to set it.
Thanks
Old Apr 4, 2005 | 04:40 AM
alarsso4's Avatar
alarsso4
1996 F150 351W 4x4: Base timing 10 deg before top dead center, +/- 2 deg. Your numbers seems way to high. Disconnect the spout connector before adjusting the distributer.
Old Apr 4, 2005 | 08:25 AM
csft's Avatar
csft
I looked for a connector to disconnect but didn't see one.
The module is on the drivers side firewall.
Old Apr 4, 2005 | 11:04 AM
termyt00's Avatar
termyt00
look near the EEC you'll see a 2 wire plug with what looks like a little gray cap, that is a jumper, remove it to set the timing. replaced it when you are done setting the timing.
Old Apr 7, 2005 | 05:01 AM
csft's Avatar
csft
Thanks
I found it, thanks alot.
I don't understand why ford put a sticker that said the timing wasn't adjustable though.
Old Apr 7, 2005 | 08:36 AM
termyt00's Avatar
termyt00
Enviromental Concerns...
Old Apr 7, 2005 | 12:13 PM
EPNCSU2006's Avatar
EPNCSU2006
Probably so people would take it to the dealership for service.
Old Apr 7, 2005 | 01:37 PM
termyt00's Avatar
termyt00
I wonder how much the dealer would charge to set the timing?
...arm?
MattP51
Jun 29, 2011 09:03 PM
baitmaster
Sep 13, 2005 12:19 AM
Rintin69
Sep 11, 2005 09:20 PM
bartll
Mar 18, 2001 03:45 PM
