In a BIND! Replace 98Exp ALTERNATOR ?? HEP...HEP !
After an extended run on the highway (about 200 miles at 75 ).....the amp guage was showing low.....it fluctuated a little during the trip...then last night when the lights were turned on....things started getting dim....and after parking...the battery did not have enough to start up.
I got a jump....and it started right up. I got back okay and now I need to replace something.
I would normally just replace the alternator. However, this happened just a few days After replacing the serpentine belt...so I wonder.
At 150K miles, the alternator has NOT be replaced....so....Is this just a coincidence that it went out right after replacing the belt (which had also never been replaced)......or does this happen at times and is somehow related??
I'm SURE the belt is installed/routed properly.....it is nice and tight...stuff spins fine.
Also...Changing the Alternator looks like just a Bolt-On job....is it as easy as it looks...or do I need to be aware of anything tricky?
(98 Explorer XLT 4x4 SOHC 4.0L 6cyl)
This is my only vehicle...so...I'm kinda in a bind.
THANKS MUCH !
It was the alternator after all.
I suspected it was since the lights did not come on after the jump...they were as dim as ever and eventually went out.
My "bind" was just that. I actually started this thread from a hotel room in GA. My father and I were there to watch a professional golf tourney (BellSouth Classic). We try to make it every year. Needless to say...I was really feeling bad about things because he was with me and I would have felt responsible for him missing the match.
That night...I checked Autozone and Advance for stock and pricing. They both had them in stock, but each was a couple of miles away. Well...guess what just so happend to be right across the road from the hotel? A NAPA warehouse which had a regular retail shop in the front! I had not checked with them thinking they would be the most expensive and only have new in stock....but....as things would have it..they had the Cheapest price of all.
There was target just down the road were I got a cheap-o socket set. A couple of sockets shattered on the first turn....but I at least had the socket wrench and got a REAL deep socket from NAPA.
In about an hour or so....it was installed....I got my refund on the core...and we made the tourney by noon. It all worked out in the end. I said a prayer of thanks soon afterwards.
And if you happened to see the Monday ending on the Golf Channel.....we were sitting right on the edge of the green in those big canvas camping chairs when Michelson made the winning put on the FOURTH playoff hole...it really was an incredible ending.
Thanks
