Where is this sending unit?
Old Apr 3, 2005 | 10:43 PM
duback66's Avatar
duback66
89' f-150 with 300 I-6. I am trying to find the sending unit that controls the temp. gauge. I have had several different answers. Some say it only has one that controls both the computer and the gauge. Others say it's on the drivers side of the block, and others say the passenger side. Can anyone tell me where this is?
Old Apr 4, 2005 | 12:38 AM
drewcoolness99's Avatar
drewcoolness99
On your 1989 FORD TRUCK F150 1/2 TON P/U 2WD, the COOLANT TEMPERATURE SENSOR is:
UNDER HOOD, CENTER, FRONT ENGINE AREA, MOUNTED IN TOP
OF WATER OUTLET
off autozone.com
hope it helps
Old Apr 4, 2005 | 06:14 AM
EPNCSU2006's Avatar
EPNCSU2006
It is a one wire sending unit, separate from the water temperature sensor for the computer. I'm not familiar enough with the 300 to tell you where it is, though.
Old Apr 4, 2005 | 09:45 AM
mike L's Avatar
mike L
Haynes manual says Ect has a Lt. green wire with yellow strip and a black wire with a white strip. Also called a ECT, engine colant temp. sensor for 87 to 89. Did you find it?
Old Apr 4, 2005 | 11:43 AM
andym's Avatar
andym
Ok, there are two sending units. One is for the computer, and the other is for the gauge. The one for the computer is front and center. The one for the gauge is on the passenger side at the rear of the block under the exhaust manifold. Most easily reached by pulling the starter.
Old Apr 5, 2005 | 10:31 PM
duback66's Avatar
duback66
Thanks. I know that there is one at the front top of the engine near the thermostat with two wires on it. I will go out and check for the other one around the starter.
