Sponsored by: Kumho
bleeding brakes
Old Apr 3, 2005 | 07:23 PM
mike9762's Avatar
mike9762
bleeding brakes
can anyone walk me through how to bleed my brakes on my 1977 f250 4x4 highboy????brakes are kinda new and the pedal seems way too low . any help please??? thanks mike
Old Apr 4, 2005 | 05:48 AM
SRD4X4's Avatar
SRD4X4
Check the rear adjustment,if the system hasn't been opened you shouldn't need to bleed them.
Old Apr 4, 2005 | 02:46 PM
mike9762's Avatar
mike9762
how do you check the rear adjustment???????????
Old Apr 4, 2005 | 04:17 PM
buzzbait65's Avatar
buzzbait65
you said the brakes are kinda new, who did them ?........
the rear drum brakes are very simple yet are complicated by some things being done wrong ( shoes on backwards, adjuster in backwards, adjuster on wrong side, improper adjustment, etc...)
has the pedal been going down slowly ?, has it always been low since the brake replacement ?, are the wheel bearings tight?
Old Apr 4, 2005 | 04:27 PM
mike9762's Avatar
mike9762
3 months ago they were super sensitive just had to tap them now im pushing all the way down
Old Apr 4, 2005 | 04:31 PM
buzzbait65's Avatar
buzzbait65
did you do them ? I need to know what you know about the system.
if the adjusters are on the wrong side they will unadjust themselves
Old Apr 4, 2005 | 04:35 PM
mike9762's Avatar
mike9762
dont know bought the truck after they were done they were great for a while and seem to be getting worse
Old Apr 4, 2005 | 05:40 PM
andym's Avatar
andym
See if the adjusters are on the wrong side. If you take the adjuster from the left side and put it in the right side, the brakes will de-adjust themselves. That's what it sounds like has happened.
Old Apr 4, 2005 | 06:22 PM
buzzbait65's Avatar
buzzbait65
the problem is that checking that isnt that easy, full floating d60's need to have the drum/hub removed (i am assuming it is a full floater, most were) which is a little more than just pulling a drum, that is why i asked what you know about the system, you can check it by adjusting the adjuster wheel, you know if you are going the right way if it clicks as you rotate it, (it should not rotate backwards, if, it is installed with the proper self adjusters in place) it should tighten the drums on the shoes fairly quickly, (do not over tighten, you should be able to turn the drum by hand) if you notice you are adjusting for a while and there is no drum to shoe contact, then they are probably installed on the wrong sides of the truck
ALSO
I have seen properly installed drum brakes wear very fast if they were contaminated by sandy mud and not cleaned, and i dont know what your truck has been through.......
