transfer case problem
Old Jan 24, 2001 | 07:29 PM
billyb's Avatar
billyb
i posted to the transmission section earlier about my transfer case popping out if gear while driving. since then, i let the fluid out and i'm getting plastic!! peices coming out. what is this?? it still drives in lw, but grinds in high. HELP!!
Old Jan 25, 2001 | 10:10 AM
cgl's Avatar
cgl
What year and model truck is it? Is it a manual transfer case or electric?
Old Jan 25, 2001 | 10:32 AM
PAUL_2's Avatar
PAUL_2
If its the BW 1356 then about the only thing inside thats plastic is the oil pump pickup tube . If the pickup tube has broken loose youd be best advised not to drive the truck until its repaired .
Old Jan 25, 2001 | 11:06 AM
cgl's Avatar
cgl
In my 1356, the tips of the shift forks have a teflon / plastic insert in them. Maybe to reduce metal to metal contact. There is also a spring that presses against the shift rail.
I have a breakdown of the 1356 that I got from my dealer, I could scan it and post it if needed.
Old Jan 25, 2001 | 02:22 PM
billyb's Avatar
billyb
pulled the transfer case today. it is a np208, by the way.
there is a part called an annulus gear that is made of nylon!!
it is gone to shreds. time to rebuild.
Old Jan 25, 2001 | 04:59 PM
shami02's Avatar
shami02
