Front 4x4 doesn't seem to be working, Help !
We got in some loose gravel today to determine what we had - put in 4-Hi & 4Lo, but we never could get the front wheels to spin. The shaft to the front Dana44 HP turns but not very fast, slow in fact.
We even put the truck in the ditch, spinning the rear wheels and the front wheels never did spin. Although when you turn you can feel the front wheels grabbing, ever so slightly, or mayby it's just my imagination.
When locking the hubs - from Free to Lock, it feels way too loose and there is no "engagement" feeling in the Lock position. But there is a "detent" feeling when placed in Free.
I would appreciate any and all helpful comments. This all seemed to work fine during the test drive (of course).
Is that it is not necessarily your hubs that are the problem but more likely something in the transfer case is not working right. It sounds like the vehicle is not going into 4WD drive and not supplying power to the front drive shaft and differential.
I would check to see if the control system to the transfer case is actually working.
That is my slightly educated guess.
Good Luck,
Jim Henderson
