Sponsored by: Auxito
Lights problem
Old Apr 2, 2005 | 08:13 PM
knw's Avatar
knw
Lights problem
The "Door Ajar" light stays on, and when the truck is turned off the interior lights and the lights on the rear of the cab stay on. ????
Old Apr 3, 2005 | 03:00 AM
fordguy21's Avatar
fordguy21
Hello and welcome to FTE!!!
As a friendly suggestion, I would avise you to use the search function before starting a new thread, as some problems have already been discussed and solved. It also would save you time as you would not have to wait for someone to reply to your post.
The problem is the switch that controls the interior lights is in the door and sometimes gets junked up, so all you need to do is spray some wd-40 or some silicone spray to clean and lube the switch.
again welcome and thank-you for becoming a member of the number one (at least IMO) family ford truck site.
