c70f carb question
Old Apr 2, 2005 | 12:59 PM
joeymac64's Avatar
joeymac64
c70f carb question
i am running this carb on my 61 390 hp the numbers on the carb horn are
C7OF-3510-A OR C7OF-9510-A which is a 735 single pump dual feed manual choke carb i believe i want to put an electric choke on this carb but holley needs to know if it has an external vaccumm or an external vaccumm any body know which one it has so i can order the right set up
Old Apr 2, 2005 | 09:45 PM
Bear 45/70's Avatar
Bear 45/70
What? Try giving the list number instead of the Ford numbers. I would think that it is a 600 rather than a 735 as the 428CJ's didn't come out with 735 carb until the1968 model year and your Ford numbers say its a '67 model year.
Old Apr 4, 2005 | 11:31 AM
joeymac64's Avatar
joeymac64
where do i find the list #s on the carburator
Old Apr 4, 2005 | 05:36 PM
Bear 45/70's Avatar
Bear 45/70
The list number should be on the drivers side, front of the carb air horn that houses the choke butterfly valve.
Old Apr 4, 2005 | 09:44 PM
joeymac64's Avatar
joeymac64
the list # is 3793 = 644
Old Apr 4, 2005 | 10:05 PM
Bear 45/70's Avatar
Bear 45/70
I find no Holley number of 3793. Holley has no 37XX carb numbers. Check here and see;
http://www.holley.com/HiOctn/ProdLine/CarbList.pdf
