360 to a 351W?
Old Apr 1, 2005 | 10:55 PM
Jamie Miles's Avatar
Jamie Miles
360 to a 351W?
I have a 71' F-250 Custom, and I blew the 360 up in it.
My friend's dad has a 73 or 74 F-150 with a strong running 351W and blown C4. To swap the engine what will I need to swap over from the 73? Someone told me on this forum a while back that the 351W will bolt to the stock 360 frame perches, but I have seen a few posts on here that make me wonder about that? If not will the perches from the 73 bolt onto the 71 frame? I have read on here that 65-79 the frames were the same up front?
I have a C6 out of a 78 E150 van that was behind a 300 I6 that I am going to use for the transmission.
I have the front end completely taken off the truck so it is fairly easy to slide the engine in and out. I will probably have the 73 here in the next couple of weeks, just trying to figgure out what I gotta do until then.
Thanks.
Old Apr 2, 2005 | 10:34 AM
Mike G's Avatar
Mike G
Just unbolt the motor from the 73 at the frame and swap over the perches and all, that is your easiest route. If you install the motor/trans combo, you will be in the best spot...
--Mike
Old Apr 2, 2005 | 10:37 AM
durk's Avatar
durk
you will need the 351 perches but they will bolt to the 71 frame. you will also probally need the radiator. it is a fairly easy swap. and according to what trans you have you may need to get a new drive shaft. but good luck with the swap.
Old Apr 2, 2005 | 10:53 AM
Jamie Miles
Smile
Thanks, thats exactly what I wanted to know and hear.
My F-250 seems to have a bigger, thicker radiator then the 73 and my 69 F100 parts truck, so I would rather keep it if possible. I'll change it if I have to.
Also, since my truck already had a C6 in it I am hoping the newer C6 will almost be a bolt in.
It's raining like crazy, so I can't do anything to it today.
I appreciate it guys.
