Batt Light flickers
Old Apr 1, 2005 | 09:47 PM
TBonez1973's Avatar
TBonez1973
Exclamation Batt Light flickers
Hi, I have a question ?
I own a 2000 F 250 PSD 7.3L today while driving the Batt light started flickering on and off. I pull over and found nothing wrong under the hood. Batt Instrument Gauge reads 14v Engine sounds and runs normal. Has Anyone seen this before. I'm wondering if this could be a simple battery repalcement or somthing more, The battery was replaced year ago at that time the Batt Light did not come on.
Thanks T
Old Apr 2, 2005 | 11:35 AM
TBonez1973's Avatar
TBonez1973
Batt light flickers
Thanks T
Old Apr 2, 2005 | 12:49 PM
barebackjake's Avatar
barebackjake
sounds like the alternator is starting to die to me. i would have your alternator tested. i know autozone does it. have both batteries checked also.
Old Apr 2, 2005 | 05:43 PM
444dieselrod's Avatar
444dieselrod
Yes. Definetly alternator. Been through two. both did the samething, flashing battery light. one was even under warranty from Napa.
Diesel Rod
Old Apr 3, 2005 | 07:04 PM
TBonez1973's Avatar
TBonez1973
thanks for the response
Turned out to be the alternator, the diodes were blown but the alternator was still charging. Unfortunately none of the parts stores I went to had the diode kit so I had to get the whole unit. ouch!
-T
Old Apr 3, 2005 | 07:50 PM
kalsc's Avatar
kalsc
What did the alt end up costing you? And with how many years warranty?
Cheers!
