Hard Hot Starts.
Old Feb 5, 2001 | 03:40 PM
laka's Avatar
laka
Hard Hot Starts.
My 90 F-150 302 5spd has been having trouble with hard starts lately. The thing barely chanks after i've been driving it for a while. Battery is brand new, and alternator is fairly new as well. I've heard that sometimes if your engine has headers that they excessively heat up the starter which causes it to draw a lot more power from the battery. My truck has stock exhaust. The truck starts fine after I let it cool down for 15 or so minutes. Any suggestions would be appreciated. Thanks
Old Feb 5, 2001 | 04:08 PM
cgl's Avatar
cgl
Hard Hot Starts.
It doesn't have to be headers. It can be the stock manifold's as well. My truck did the same thing. After parking on hills for two days (a nice thing about a clutch), I replaced the starter and it's been fine ever since.
Old Feb 5, 2001 | 07:25 PM
windsor's Avatar
windsor
Hard Hot Starts.
I've found problems on my 95 F150 and other fords and it always seem to be the ground cable from battery to block (front rh bottom corner.)It always gets corroded and loses contact.I cleaned it and either relocated it or put it in original spot if I had no other options.Im assuming your timing is fine..Right??
Old Feb 5, 2001 | 08:47 PM
trouble's Avatar
trouble
Hard Hot Starts.
