Sponsored by: Real Truck
Super duty purchase
Old Apr 1, 2005 | 05:21 PM
catfish05's Avatar
catfish05
Question Super duty purchase
Need some info on s/d 2004 vs 2005 am loking at a 2004 with 19k miles v10, what can I expect for mpg? Should a person get the new 3v eng. or are the 04 v10s as good and reliable? what about anyone running k/n air intakes, and or after market cat back mufflers? Any information will be greatly appreciated.
Old Apr 1, 2005 | 05:55 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 1, 2005 | 06:25 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
the s/d 05 has a better turning radius than the 04. The 05 has a different suspension than the 04 , coil springs vs leaf springs(04). What are you planning on doing with the S/D? Go to www.kbb.com and see what a 05 vs the used 04 is in price. I found getting new VS used was the same price per month because of the interest rate difference and terms. So after many years we bit the bullet and got new. It is a hard decision to do but good luck.
Old Apr 1, 2005 | 06:28 PM
PrarieOyster's Avatar
PrarieOyster
major differences
04 front leaf springs (4x4) , 05 front coil springs (04 and 05 2wd coils springs)
04 4 speed automatic , 05 5 speed automatic (gas engines)
04 2v gas engines. 05 3v gas engines
gas mileage is practically the same
05 has a stronger frame
05 has 17" stock standard wheels, 04 16"
05 has different grill.
05 has higher gvwr ratings
both are good trucks. I personally would order an '06 which is similar to an '05 but should have better reliabiltiy than the '05. I prefer the leaf springs over coil, but I like more HP, bigger wheels and stronger frame.
Old Apr 1, 2005 | 07:43 PM
BigF350's Avatar
BigF350
FTE Emeritus
catfish05:
It all depends on your personal finances.
If you can afford the 05. GET IT.
The torqshift is so much better than the 4R100, the 3V V10 makes a fair bit more power than the 2V.
The chassis has improved in leaps and bounds. Brakes, stiffer and stronger chassis, coils on the front etc. Higher GVW's
You can expect about 10-11mpg in city, about 14mpg sitting on 70-75 on the highway. This depends on configuration of course.
