swapping from stick to automatic
Old Apr 1, 2005 | 04:20 PM
oldblue31's Avatar
oldblue31
I have a 76 hiboy with a 4 speed manual and divorced np 205. I was interseted in swapping to an automatic and wonder what all this entails.
Old Apr 1, 2005 | 06:10 PM
GeneStoner's Avatar
GeneStoner
Well besides acquiring your new tranny/torque converter/flexplate (maybe starter), you will need to get a different driveshaft or modify yours depending on the length of the unit you get. Try to get the transmission cross-brace too as you will need that to support the auto tranny. Also, you will have to cool the trans, so either you will need a different radiator and tranny lines or plumb in a large aftermarket cooler.
You may need to adjust where your NP205 sits on the frame, but not having done that exact conversion, I don't know offhand...
Good luck
