horn/signals/column
Old Apr 1, 2005 | 02:08 PM
spitfyre's Avatar
spitfyre
horn/signals/column
i know ill probably make some people angry with tis but my stock 2 spoke wheel is about 1/4 inch from the column and the horn and signal returns only work if i push the wheel into the column, would this be fixable by adjusting the column, buying a new ragjoint or coupler or what. also any other tips on what i should do while restoring the truck, im currently in the process.
Old Apr 1, 2005 | 02:23 PM
4Cammer72's Avatar
4Cammer72
check your front cab mounts to see if they are colapsed. if they are it could be pushing the column up into the cab.
Old Apr 1, 2005 | 02:30 PM
spitfyre's Avatar
spitfyre
the mounts are good, i have the floorpans cut off so theyre easy to access, im thinking of welding in a plate as a sort of preventive maintenance
Old Apr 1, 2005 | 02:49 PM
4Cammer72's Avatar
4Cammer72
then check the rag joint to make sure its seated all the way down on the steering box. there should be a bolt sideways on the shaft through the rag joint mount. if its not there it could be creeping up and pushing the column shaft towards you
Old Apr 1, 2005 | 03:00 PM
spitfyre's Avatar
spitfyre
k ill check that monday, unfortunately i cant do weekend work im doing the truck in my schools shop
Old Apr 1, 2005 | 04:04 PM
qman's Avatar
qman
There should be no movement in your column. Figure out what gives and fix it.
Bigbruce
Jun 23, 2013 08:35 AM
flamesoldier
Apr 17, 2013 12:31 PM
Kurtboyd
Mar 8, 2013 07:15 AM
e william
Feb 26, 2004 10:31 AM
nmeyer
Aug 3, 2003 05:49 PM
