Is the motor original, and if so, do you know if it was a 2bbl or 4bbl? The 4bbl's usually had higher compression, one of my books shows the 2bbl at 8.9:1
So, pick the biggest cam you can that will work with that compression.
That cam kick you linked to is a 284/284 duration. That's kinda high for only 8.9:1 compression... guys?
