Rusty Bed
Old Mar 31, 2005 | 08:31 PM
JoeKnows89's Avatar
JoeKnows89
Rusty Bed
Have a long wheel base. Bed is rusted out where the bed floor meets the front panel up by the Cab. Where can I get repair panels to weld in. an can I get that support that runs under that spot on the bed? Thanks for any help give.
Old Mar 31, 2005 | 10:57 PM
LxMan1's Avatar
LxMan1
My 63 Short bed (not unibody) is also rusted out in the front bottom section. It uses the 59 style bed and I am having trouble finding any kind of panels for it. Anyone know of a vendor for these style of beds??
Thanks,
Jimmy
Old Apr 1, 2005 | 04:49 AM
jowilker's Avatar
jowilker
It's a lot of work, but you might look at using one from a later model bed.
FWIW, I was measuring the bed of a 86 that I bought and found it to be very close to my 66 measurements.
John
Old Apr 1, 2005 | 05:05 PM
LxMan1's Avatar
LxMan1
I might try that, I also thought about making it a stepside. They all fit
Old Apr 2, 2005 | 06:32 AM
jowilker's Avatar
jowilker
I have a photo some where on my HDD of a later bed that has been reskinned with 66 sides. That is above my ability.
John
Old Apr 4, 2005 | 07:50 PM
LxMan1's Avatar
LxMan1
I have a short bed that is like the 59' bed since it is not a unibody. These trucks must be pretty rare since most of the 63's that I have seen on this site and anywhere else are either stepsides or unibody's.
I dropped mine off at a body man on Saturday. It is getting new floor pans, some small rust spots such as cab corners and such replaced/repaired. The bed is the worst of it. The sides are not real bac, but the bed bottom and the passenger side area where the tail light is needs major work. There are pic's in my gallery. It's a 63 CustomCab. It has 92,000 original miles and now sports an 84 351W/C6 with a 28 spline 3.50LS 9".
Old Apr 4, 2005 | 11:52 PM
CustomCab4x4's Avatar
CustomCab4x4
Smile
I had to make a repair panel for my 64's bed when I found out I couldn't buy one.
Here's a link to a drawing that you can use to make a panel. This will only fix the leading edge of the floor and the lower part of the bed front. It won't do you any good for the corrugated bed floor. For that you'll need either a decent donor panel, or replace the entire floor with a new panel. In looking for a "new" floor I found that an 80-86 8 foot bed floor was identical in size but the ribs are shaped different. That being said though, it is a tremendous amount of work to drill out all those spot welds and replace the whole floor.
I ended up just going with a flat floor and used 2 4x8' sheets of 1/8" steel.
Good luck, Phil
Panel:
https://www.ford-trucks.com/user_gal...d=3912&width=2
https://www.ford-trucks.com/user_gal...d=3911&width=2
Floor:https://www.ford-trucks.com/user_gal...d=1672&width=0
Old Apr 5, 2005 | 10:47 AM
garbz2's Avatar
garbz2
When building the custom bed for the Super Crew i used the tub from a 79 truck. I removed the quarter panels and installed Uni panels on to the tub.
This method works for the earlier 57 to 66 beds or the 64 to 66 beds.
I will try to post a few pictures in the gallery of the modifications.
Garbz
Old Apr 5, 2005 | 06:47 PM
CustomCab4x4
Hey Garbz2, I would REALLY like to see some pix of that! I wish I'd thought of that when I redid my bed. In hindsite, that might have been easier. Thanx, Phil
Old Apr 5, 2005 | 09:42 PM
LxMan1's Avatar
LxMan1
I'm thinking maybe some diamond plate steel for the bed floor. It is pretty bad in the front.
Old Apr 6, 2005 | 01:19 AM
CustomCab4x4
Smile
When I posted about this earlier, I completely forgot that yours is the 57-60 style bed. Sorry bout that. That pattern I was talking about wouldn't work for you at all. Hope I didn't mislead ya!
Good luck, Phil
Old Apr 6, 2005 | 10:43 PM
LxMan1's Avatar
LxMan1
Nah, Pretty common mistake. It took 2 or 3 times to get the correct tail light lenses when I ordered them a couple of years ago. They sent the unibody ones first, then sent the correct round lenses with unibody gaskets!! Not even close. I don't even remember who I got them from now, but it wasn't any of our sponsors, I'm sure that they would have gotten it right the first time
Old Apr 7, 2005 | 08:52 AM
garbz2's Avatar
garbz2
Phil
I will pull the bed out from storage this weekend and take some digitals.
garbz
Old Apr 20, 2005 | 08:36 PM
LxMan1's Avatar
LxMan1
Man, I saw the right bed that was a home made trailer. It looked ok from the road so I called and he said $150!!! But upon close inspection, it was rusted worse than mine. I was hoping the floor would be good, but it was worse than mine. Oh well, maybe one will come along someday.
