RGAZ, How is your charging system? I have seen where the batt goes low and the alt is not putting out cause a lot of problems. I have had my whole dash go crazy before. I have also seen the engine throw a nasty hissy fit when the charging system is down. I have seen this on three different trucks. Just a thought.
My truck did the same thing to me. It eventually quit and would not start again. It had no spark, so I replaced the module and the pickup in the distributor at the same time, and then it fired up and ran great again.
Charging system is fine, I had it checked a week ago.
Last night I did some poking around and when i moved the cable harness that connects to the coil, she started sputtering and died. I think i fixed it buy pulling off the connector to the coil and tightening the metal clamp so it clamps on the quick-connect tighter. It could be something else, but when I did that it ran fine.
BTW-Anyone know what the big red resistor in that harness is for? Mine was all taped up, and I retaped it.
