prodigy brake controler
Old Mar 30, 2005 | 06:56 PM
johnny8's Avatar
johnny8
Thumbs up prodigy brake controler
i just installed my new prodigy inertia sensing brake controler in my F350 SD PSD. i haven't towed with it yet. Anyone using this thing? if so, how well does it work..? any comments or recommendations..? thanks guys..
Old Mar 30, 2005 | 08:22 PM
Steina's Avatar
Steina
CO River Rat
Works great!!! I've used 4 different models from 2 different manufacturers over the years, and Prodigy is the best. Just make sure you can reach the manual control easily, in case you ever have to jerk a trailer back in line when it starts swaying.
Steve
Old Mar 30, 2005 | 08:35 PM
johnny8's Avatar
johnny8
thanks, i put it just to the left of the wheel, where i can get it easy with my left hand, my old peice of junk was mounted way down on the right, i had to bend over to reach it, and i could barely see the road when i did, i had to fix that...!
Old Mar 31, 2005 | 11:08 AM
Delawhere?'s Avatar
Delawhere?
This is by far the best brake controller that I have used and I have had several. Once you have it set for your trailer, that is make the adjustments once your hooked up, you probably won't have to do any adjustments again. You have a boost adjustment that goes by the size and weight of the trailer, plus the power setting, it is self leveling and again it is almost fool proof. Good luck and happy towing!
Old Apr 3, 2005 | 10:50 PM
karenj's Avatar
karenj
I use the Prodigy and I won't trade it for anything!!!
Old Apr 4, 2005 | 07:03 AM
CmprSpecial's Avatar
CmprSpecial
Love mine!!
The very day I installed mine I had to make a quick stop. With my old unit I would have been in deep doo doo. With the Prodigy, it was a smooth controlable stop.
What I like most is it ignores the bumps while braking. My old inertial controller would grab when I hit bumps while braking the Prodigy doesn't .
Old Apr 4, 2005 | 04:33 PM
XolieX's Avatar
XolieX
how much is the unit by itself? i think my bronco has the narness for it so i just need to plug it in to make it work.
Old Apr 4, 2005 | 05:09 PM
Steina's Avatar
Steina
CO River Rat
Olie -
http://www.rjays.com/Tekonsha/prodigy-01.htm has them for $99.99
Steve
Old Apr 4, 2005 | 06:10 PM
XolieX's Avatar
XolieX
the hook up harness, it doesn't say if its for broncos. i hope it is. that connector i can recall where in the truck that it goes.
Old Apr 5, 2005 | 04:20 PM
XolieX's Avatar
XolieX
steina thanks for the link again, i clicked on the ford one and i found where under the bronco is the female end of that connector. the harness is exactly what needs to be inside the harness inside the car.
so i guess installing this unit will be so easy compared to what i thought it would be. and i'll be able to take it out if i had to.
now only if u-haul had dollies/car transporters with electric brakes now instead.
Old Apr 5, 2005 | 04:29 PM
johnny8's Avatar
johnny8
i hope to get my 28' 5ver on Friday... then i'll be able to see what this controler can do...!
