Mallory unilite
Old Feb 18, 2001 | 08:04 PM
Franklin2's Avatar
Franklin2
Mallory unilite
Old Feb 19, 2001 | 07:49 PM
ole_blue's Avatar
ole_blue
Mallory unilite
I had a guy give me a unilite distributor for my 351C. I need to replace the pickup before I install it. Does any one know how to hook it up to the Ford Factory duraspark ignition box? Any information would be much appreciated.
FORD= Fun Off Road Driving
Old Feb 19, 2001 | 10:41 PM
jbhf250's Avatar
jbhf250
Mallory unilite
Ole Blu... The Mallory Unilite I had was in a 390 FE and it did not need anything else except a good coil...
IF i remember right the Green wire is the one that goes to the coil NEG... NOT GROUND!!!!!
The other wire(not sure which) that goes to ground has to be on a GOOD GROUND!!!
Check the mechanical weights to make sure they are FREE inside. They can hang up and cause you to crank the engine against FULL advance when starting.
Sorry i cant` be more help I gave it away last year with the paper work.
>I had a guy give me
>it. Does any one
>know how to hook it
__JOHN__Õ¿ö
FTE Club #7
Member-
http://www.cruisin-north.com/
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://www.ford-trucks.net/users/jbhf250/
https://www.ford-trucks.com/pictorial/big/1972_f250_2.html
