checking wires
Old Feb 19, 2001 | 09:11 AM
billg's Avatar
billg
checking wires
Help, I don't know #### about trucks. My problem is I want to check to see if my gas gauge works or is the problem in the sending unit. I took off the plug to the unit, now to check the gauge do I put a meter across the white and yellow wire ( these are going to the gauge) or ground out one of those wires? If the needle moves then the problem is in the unit, correct? Thanks for helping out a non-mechanic.
Old Feb 19, 2001 | 10:45 PM
jbhf250's Avatar
jbhf250
checking wires
Its been a while...but if i remember you `ground` the `power wire` going to the gauge.. Simulates a full tank. The gauge should go to full.
__JOHN__Õ¿ö
FTE Club #7
Member-
http://www.cruisin-north.com/
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://www.ford-trucks.net/users/jbhf250/
https://www.ford-trucks.com/pictorial/big/1972_f250_2.html
Old Feb 20, 2001 | 01:10 AM
PAUL_2's Avatar
PAUL_2
checking wires
Chances are the sending unit is the problem , Do as John suggested to make sure .
Old Feb 20, 2001 | 05:43 AM
rick1959's Avatar
rick1959
checking wires
DR Smith
24
Jun 13, 2014 03:36 PM
buzzurd
Apr 17, 2013 10:53 AM
Goatjacket
Aug 12, 2012 07:24 PM
fordtrck1955
20
Dec 31, 2008 06:29 PM
