Alignment question
Old Mar 30, 2005 | 12:31 AM
mtbjedi's Avatar
mtbjedi
Alignment question
I have a simple question related to alignment..
I just replaced the stock 245/75 tires with BFG AT/TAs in 265/75. I am pretty sure I don't need to get an alignment 'cause no suspension changes were made..but I just wanted to run it past you guys to make sure I don't hose my new tires
The ride is a bit higher and the tires are bigger but it seems to me that the angles should all be the same..I am just being cautious.
thx
Old Mar 30, 2005 | 04:00 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
If you're old tires were wearing ok and if there's no odd feeling in the steering (pulling for example), then you are fine. Be aware that larger diameter tires will slow down your speedometer.
Old Mar 30, 2005 | 01:30 PM
mtbjedi's Avatar
mtbjedi
Yeah, no pulling and the old tires wore fine..so it looks like I am good. Thanx.
Old Mar 30, 2005 | 06:07 PM
Rjslater's Avatar
Rjslater
What about toe-in? Never had a car or truck that upon checking the alignment did not require toe-in adjustment.
My 2 cents
davalt75
Sep 30, 2014 08:56 PM
PKJ
Sep 29, 2010 07:48 AM
Nightstalker
Aug 3, 2010 10:10 PM
scstocks94f150
Jul 3, 2008 05:50 AM
